Here is the setup.
Onkyo TX-SR 504 Receiver.
Miller and Kreisel Sub. I couldn't find the manual and didn't see the model number on the sub itself.
The LFE out on the reciever is connected to the L and R low level inputs on the sub (It doesn't have a dedicated LFE input. I used a y-splitter to connect it to both inputs). The crossover in the receiver is set to 80. The crossover on the sub is set to its maximum of 150 (I believe this is the way to do it when I am not actually using the sub's built-in crossover).
Let me know if you need more information and thanks for the help.
Just to recap, the sub crackles and pops if I change the volume (even if there is no signal and the reciever is turned off). Also there is little to no sound unless I have it set at or near the maximum volume.
My father-in-law may have been running it at near full volume for a number of years, which I fear may have damaged it. If this is the case is it possible to jsut replace the driver or could other parts be damaged as well? Or am I on the completely wrong track?
My internet access is a bit spotty at the moment so it may take a few days to respond if you need more info.
Again, thanks for the help. I have found this forum to be continually friendly and helpful.
THoff
