Bravus 8D Impressions (Mini Review)
rnatalli
I promised to post some impressions when I got a chance to hear the Aperion Bravus 8D Subwoofer so here they are.
Packaging – Just what you'd expect from Aperion. Well-packed with lots of foam and their signature blue, velvet bags. I do have a gripe as it wasn't double-boxed, but the packaging was more than enough to survive shipping. They also sent a care kit which includes cleaning instructions, a cotton cloth, and cotton gloves for handling; nice touch.
Build Quality – This thing is pretty! The black, piano gloss is stunning. I've never seen Aperion's cherry, but I imagine it's excellent. The Bravus 8D is solid. It weighs almost as much as my own HSU STF-2, but is only a third of the size. The Bravus 8D comes with a good power cord. I always felt the ones HSU includes with some models are a bit skimpy.
Features – The Bravus 8D consists of quite a few features. It comes with an LCD screen and remote which I used for setup. The LCD screen is a bit small to see from across the room and the remote doesn't use discrete codes for power and setup making a universal remote harder to program. Not a big deal really. The setup allows quite a bit of flexibility. It comes with three pre-programmed modes: music, movies, and game. I found the out-of-the-box settings quite satisfying, but you can program each mode separately with your own settings. It also consists of the usually phase adjustment which isn't simply a switch offering 0 and 180.
Sound – Ok, so how does it sound? The Bravus 8D is a dual, active 8” drivers in a sealed enclosure. The Bravus 8 sounds excellent! A hair tighter and more articulate than my STF-2 and it wasn't shy to rumble when called upon. I didn't feel output was lacking and although some very low sounds were missing, it wasn't much.
One additional observation I made is that the Bravus 8D needs good voltage from the preout to turn on. This was easily solved by cranking the SW level up on the receiver and reducing the gain on the Bravus 8D itself.
Overall, I must say I'm impressed with how much Aperion squeezed into this small box. I would have liked it doubled-boxed for shipping, discrete remote codes, and a bit more sensitive amp, but other than that, I can't fault anything else. At $499 it may seem expensive, but considering construction includes HDF, real wood veneer with piano gloss, and dual active 8” aluminum drivers, it isn't a bad little deal. I'm considering selling my STF-2 and getting the Bravus 10D which should give you an idea of how I feel about this line of subwoofers.
rnatalli
I remember having the 5B's here. Everything they make weighs a ton. Probably the 1" HDF they use in most of their speakers and subs.
rnatalli
I put some roses behind the camera to give you an idea of how reflective the glossy surface is. No flash was used.
Can you guess which subwoofer is showing in the reflection on the last photo?
lsiberian
lsiberian
New toys are so nice.
spyboy
spyboy
You seem to think that HDF, high density fiberboard is better than MDF, medium density fiberboard.
For subwoofers, MDF is Not inferior. In fact, MDF is the CHOSEN density.
Mega buck subs use MDF.
More dense is not always better, including in the build of subwoofers.
Matt34
Matt34
Moderator
I don't see where he said that but ok. Keeping with the topic however, I would figure the denser the material used, the less loss in energy it would have and at an inch thick.....that is more than most subs at this price range offer.
I'm sure Aperion advertises this specifically as a marketing tool more than anything but it does have a slight advantage on paper.
rnatalli
I agree that MDF is fine for all practical purposes. My only point was to show that Aperion did not skimp on materials.
spyboy
spyboy
And my point is that Aperion is trying to mislead people who don't know any better by suggesting that HDF is superior to MDF, when the contrary is true.
The wood product that some find preferable to MDF is 13 ply Baltic Birch plywood.
rnatalli
"Small Internally Braced ¾” HDF Sealed Enclosure
Powerful bass needs a sturdy cabinet. Every Bravus D8 subwoofer is built out of strong ¾” HDF and internally braced to reduce cabinet vibration to nearly nothing."
That's straight from Aperion's site. I don't see anything deceptive about that statement.
mg428
Bravus 10D seems to be a better option since it can reach lower frequency response rates.
F
fredk
Damping is all about mass. More mass = more damping = less vibration.
