<font color='#000000'>Many years ago, Consumer Reports tested the Bose 901's and gave them a negative report, which resulted in a lawsuit by Mr. Amar Bose himself. From then on in the audiophile community, the company was known as " I'm Amar Bose, and I will sue you if you don't like my speakers" Company.
In their days the 901's were a radical design compared to other speakers. I believe they were the first speakers to attempt to use the wall and corners behind them (sort of an early dipole) to add room ambiance to the sound. unfortunatey, the results were not good. If I remember they correctly, used eight 4" speakers in an angled enclosure firing at the backwall and one 4" speaker in the middle of the front baffle firing forward. Because this speaker array was very hard to drive with an uneven frequency response, an equalizer was provided with the speakers to attempt to straighten things out. Needless to say, the audiophile community was appalled by the Bose attempt to use the room walls to add ambiance (coloration) to the sound. All this sound bouncing around messed everything up going through them, completely obilterating any well engineered recordings.
Times sure have changed ,eh!!, with YPAO etc. trying to adjust speakers to eliminate room sound from the listening equation.
So if you have 901's in the garage, leave them there. If you have a boat, use 'em as anchors!! Unfortunately, their current line of speakers are to small to use as boat anchors individually. You will have to put them in a sack first.
Al</font>
