box size vs. transient response
Guiria
Guiria
Is there a direct relation between box size and transient response?
Or...
Is transient response primarily governed by the quality of the driver?
Swerd
Swerd
Is there a direct relation between box size and transient response? Or...
I don't believe there is a simple direct relationship between box size and transient response.
The driver, as far as I know, is the main source of fast or slow transients. In the lower bass frequencies, poor cabinet design, with a Q > 1.0, that creates an exaggerated bass hump around 50-100 Hz, also generates slower transients, or ringing, from an other wise good bass driver.
annunaki
annunaki
Moderator
Well stated!
Total system Q
The size of the box is determined by the Thiel Small parameters of the driver. However the final result can be tweaked. Drivers have mechanical and electrical resonances. The box has a resonance. These resonances have notches of varying steepness. This is the Q of the resonance. The sum of all the above is total Q. If the total Q of the system is 0.5 the bass will have a tight quality, that I think is just the wrong side of natural. If the Q is greater than 1.0 it will be boomy. I like a total system Q between 0.7 and 0.8
annunaki
annunaki
Moderator
I agree!! :)
Warpdrv
Warpdrv
How do you calculate what the Q will be for your boxes?
annunaki
annunaki
Moderator
For sealed enclosures it is pretty straight forward and important when using a modeling program. Finding the ideal enclosure for for ported, the formula is:
Enclosure volume: Vb = 15 Vas (Qts^2.87)
Theoretical cut-off frequency: F3 = 0.26 Fs (Qts^ -1.4)
Tuning frequency: Fb = 0.42 Fs (Qts^ -0.9)
^ is equal to squaring or the power of
