Boston Acoustics TVee 26 Theater System with Wireless Subwoofer Overview
  • Thread starter Thread starter HTKamikazee
HTKamikazee
Audioholics Sheriff
Oct 24, 2012
282
0
28
With the soundbar-mania all over the globe, here is yet another nice product from Boston Acoustics: the TVee 26 Theater System with Wireless Subwoofer from Boston Acoustics.
Like most soundbars, this system will significantly improve your audio experience with the included 2.4 GHz wireless subwoofer. This product has Dolby Digital 5.1 decoding, a dedicated music and movie mode, and features what Boston Acoustics calls Digitally Optimized Virtual Surround (DOVS) technology and BassTrac circuitry.
This is how Boston Acoustics explains this technology:
"DOVS uses sophisticated digital processing to create a fully immersive, cinema-quality sound experience, whether you're listening to music, watching a movie, or playing a game. In addition, Boston's BassTrac circuitry delivers rich bass without distortion."
For better convenience, it has digital and optical analog inputs to provide flexibility. Also a mini stereo AUX input is available to connect to your mobile devices so you can play your audio material as well.
As for amplification, the TVee 26 is a self- amplified device which means you won't be needing anything else to use it - which is always a good thing for those who are looking for a simple and easy audio solution. Just connect it to your TV and you are ready to go!
For added convenience, the TVee 26 can be operated by using any of your existing TV, TiVo, cable box, or satellite box remote controls. Soundbars offer a lot of flexibility when it comes to placement as you can place them on top or below your display and be ready in just minutes.
What's in the Box?
TVee 26 soundbar, speaker grill, wireless subwoofer, analog cable, digital optical cable, owner's manual, and quick-start guide.
Check out the following features and specifications:
FEATURES:
  • Simple installation with no need for a receiver.
  • Digitally Optimized Virtual Surround offers fully immersive sound.
  • Operate with your existing remote control.
  • Includes soundbar and 2.4 GHz wireless subwoofer.
  • Dolby® Digital and Boston's Digitally Optimized Virtual Surround to provide clear, realistic sounding home theater.
  • One optical digital or analog stereo mini-plug connection is all you need to improve your TV's sound.
  • Learns your existing remote control's volume and mute commands.
  • Two 2" x 5" HHRT full-range drivers.
  • Light, rigid HHRT speaker cones reduce distortion and enhance dynamic performance.
  • Dedicated movie and music modes.
  • Touch-sensitive controls.
  • Built-in transmitter sends audio signals to wireless subwoofer.
  • Keyhole slots for wall mounting.
  • Wireless woofer: plays bass and mid-bass frequencies.
  • Allows placement anywhere in the room.
  • 6-1/2" down-firing bass driver
  • Connections: 2 analog stereo mini-jack AUX inputs / 1 optical digital audio input.
  • Stereo mini-jack and optical digital cables included.
SPECIFICATIONS:
  • Enclosure; Bass Reflex
  • Pieces in System: 2
  • Color: Black
  • Tweeter: None
  • Midrange: 2" x 5" Cone (2)
  • Woofer: None
  • Separate Subwoofer: Yes
  • Subwoofer Driver: 6.5" Cone
  • Bluetooth Connectivity: No
  • Wall-mountable: Yes
  • Mounting Bracket Included: No
  • Surface Mount Stand Included: No
  • Speaker Parts Warranty: 1 Year
  • Speaker Labor Warranty: 1 Year
  • Amplifier Parts Warranty: 1 Year
  • Amplifier Labor Warranty: 1 Year
  • System Frequency Response: 45-20k Hz
  • Powered System: Yes
  • Sound Bar RMS Power: 150 W (total system)
  • Subwoofer RMS Power: 150 W (total system)
  • Audio Inputs: Mini Stereo Audio Inputs x 1 / RCA Stereo Audio Inputs x 1 / Optical Digital Audio Inputs x1 / Coaxial Digital Audio Inputs (No)
  • HDMI Inputs: No
  • HDMI Outputs: No
  • Sound Bar dimensions: 3-1/4" H x 31-9/16" W x 3-1/8" D
  • Sound Bar Weight: 4.8 lbs.
  • Subwoofer dimensions: 9-5/16" H x 10-1/2" W x 12-7/16" D
  • Subwoofer Weight: 6.6 lbs
  • Warranty: 1 year
Price: $299.99
Click on the following thumbnails to zoom in.
