mcdanielnc89
Hello everyone... I'm wanting to connect my laptop to my tv, but I need some type of bluetooth adapter for the tv. Is there such thing?
Also, what about something where I can stream my pc sound to my surround sound via bluetooth?
BMXTRIX
BMXTRIX
Bluetooth doesn't have the bandwidth to carry video. If you want quality VGA video or DVI/HDMI video from your PC, wirelessly to your TV, then you need a proper wireless solution...
http://www.gefen.com/kvm/dproduct.jsp?prod_id=8372
If you need audio as well, it will send standard stereo out of the PC.
This is a halfway decent solution to what you want to do, but the most typical way to connect a PC to a TV is the same way you connect a PC to a monitor - run a wire to it.
