Which wire should I order.
W warnerwh Full Audioholic Nov 19, 2004 #2 Privateer said: Which wire should I order. Click to expand... It really doesn't matter. The 1800 has less capacitance than the L-4E6S but I use the latter and it's fine. If you're going for very long runs it would probably be safer to go with the 1800 but it also depends on the component. On my Audio Research pre they recommend keeping capacitance down below a certain value (1000) and someone more knowledgeable than myself may know of other possibilities that could cause a problem but it's doubtful.
