Blu-ray DVD player problem
Pryso
I have a Panasonic which is about 10 years old. Following a recent long distance move (packed in original box) it happened that I only played a few regular DVDs before attempting to watch a Blu-ray disk. When I did I was surprised to see a message it could not read the disk, even though it had been viewed before on this machine.
So I tried a couple more Blu-rays but again received message they could not be read. I began shopping for a replacement but decided to try one more time. Again loading different disks I initially got the same read failure. I also noticed the read time was longer than I remembered from when it was working. Then with one disk after seeing the same message I reloaded it. This time it began playing but did exhibit some pixilation.
The deck still plays regular DVDs normally but fails with Blu-rays. I don't know enough about them to understand if the reading mechanism for Blu-rays is separate from the standard laser reader? I assume there is nothing to reset on the Panasonic itself?
Because of the age of the deck I expect the only reasonable answer is to replace it rather than try for a repair?
G
Gmoney
I have a LG player it won't read blu-ray disc but will play DVD and music CD,s. I found only one blu-ray it will play a older one I have but won't play any newer blu-ray disc. Dam the bad luck.
DVDs and blurays don't use the same lasers in the player. I suspect there is nothing you can do but replace the player....a reset to factory settings wouldn't hurt, tho (if it has such).
The move has got the Blue laser that reads BD discs out of alignment. You will have to send it in for service or replace it.
Pryso
Thanks. I wondered if there might be two reads and possible shock damage from the move? That was why I included that information.
