Blu-Ray demo disc...
1
1tribeca
I'm sure this has been asked before...but does anyone here know where one can purchase, or get a hold of the Blu-Ray demo disc with the "Cronicles of Narnia etc. on it? I've seen another demo disc on Ebay, but a different one.
No, I haven't purchased a Blu-Ray player yet so I don't have one.
OR...can the aforementioned disc be copied easily and with the same quality?
I don't follow you? You cannot play back Blu-ray disc without a Blu-ray player...so no you can't copy it to another format and expect the same resolution.
1
1tribeca
No, no...I mean copy it to another Blu-ray disc. Perhaps it wouldn't be an issue. I know there is rec'd blanks out there...not cheap I realize but available. Since these demos are usually overdone...much like audio demo discs (coloured if you will) I was just wondering if an identical copy could be made.
Yes it can be done, there are Blu-ray drives and burners available. Last I checked, the drives were around $500 and the burners were FAR more expensive, around $1k. They may have come down since then though, with the player price dropping pretty significantly recently with the second generation.
