Briant73
Hi to everyone, long time reader but newb poster. I just bought some the pre-terminated BJC white 10 gauge cable and thought I would share my thoughts on it.
Product: I ordered three cables of same length and type (10 gauge, white banana terminated).
Service : I ordered on a Friday and received them Monday. Cables were packed nicely.
Lentgh: I then decided to check cables for length variances since I heard some custom cable manufacturers don't always meet the length or keep it consistent. All cables measured the length I wanted them to be (actually because of the connectors seemed to be about 1-2" longer than what I specifed) and all the cables appeared to be consistent to each other.
Appearance: I like the apperance very professional but not exotic. The white really goes nice and having a black and red wire at each end just makes things that much easier to tell. The Banana connectors appear high quality also.
Build: The cables appear to be well built and fastened to the banana connectors securely. The banana connectors are the screw/locking type and very nice.
Sound: I know this is very subjective and I didn't measure with a meter but it seemed that I was hearing the sound louder at the same level than my old Monster THX speaker wire. I can say I noticed no problems with the sound.
I would recommend these to anyone looking for pre-fabricated cables with quality connectors.
jaxvon
jaxvon
I guess he thinks it's free marketing for Blue Jeans. I guess so, but it isn't really self promotion. Look at all the other people here that post about their feelings about BJC...the company can't be paying them all. Is it possible that they just offer a quality product at a good price without any of the marketing BS?
Briant73
As I said in my first post I am a long time reader but new poster to this forum and many of the postings by users here of their experiences/knowledge have helped me when making audio/video purchasing decisions. I have seen very little about the BJC speaker cables so I figured it was only fair to share what I knew and thought. I didn’t mean for my message to sound like promotional material in the least, just my observations and thoughts. I just think it's a decent product IMO. From reading other message detailing others views and experiences I guess I should of added why I changed to these cables and anything that might be a con about them. Here it goes:
In my earlier post I said I changed from Monster THX cables, there were two reasons, the first being the monster cables were falling apart. Twice under warranty I had to have the copper wire reconnected to the banana connectors and the other cables appeared to be going down that road (the vinyl covers from the cable to the banana connector were a mess too). My second reason is purely subjective but I always felt my system didn't sound as loud as it should be and I read some reports that said certain monster speaker wire back in the day had problems. Based on those two reasons (mainly the idea of the cables falling apart) I decided to change out to some pre-built speaker cables with banana connectors.
I have read many sites that pretty much agree a well-built cable, quality connectors, and with quality wire should do the job as well as any other. I also remember reading reports of some hardware store brand speaker wire and Monster wire that had problems mainly that it started to turn green/oxidize. With all that knowledge in mind I decided to look based on this criteria:
1) Pre-built (As I said don't mind cabling but never been big on making it look good. Wanted well made but didn't need glowing lights or exotic patterns).
2) Locking Banana connectors (Easy to use and durable)
3) Quality of wire/cable (Decent Gauge, OFC, good jacket)
4) Cost (Something that won't break the bank but I wasn't pinching penny's either)
Blue Jeans cable met my criteria so that's why I chose them.
Here are some cons I thought of:
If price is your main concern your probably better going with building your own or looking around. Though there are more expensive cables there are also cheaper.
If the cables appearance is a major concern then there are brands that really make eye-catching cables. I do hear though that BJC does custom work so you may want to check with them about appearance.
If you want something flat for wall runs then this isn't the cable for you pretty thick round cable.
BTW I almost didn't consider BJC because awhile ago I tried finding out some information about their coax video cable and never got a response from them after I e-mailed and I read some things on another forum that weren't complimentary to the way BJC is run. I changed my mind because they have been in business for a while and many more people seemed to have good experiences with them. Also the product fitting my criteria helped.
