Bi-wiring rears? waste of time?
Johnny Canuck
Johnny Canuck
As i am moving soon, I will be re-wiring my system...I have the option of biwiring all my speakers. However, I run an amp on my lows and the receiver runs my highs so that is not an option on my fronts.
I currently biwire my centre channel.
is it a waste of time to bi wire my rears? Is it better to biwire or is it better to use 10 guage, single run?. Bluejeans has biwire for $1.10 a foot, still affordable.
I am also thinking of going back to barewire instead of bananas....Bluejean recommends this...why put a crappy connector in the middle of a direct connection.
L
Leprkon
do you use your rear speakers for mostly HT or for multi-channel audio ? if for HT, they are never loaded to the point where they would need anything more than 12 gage, and only that for a run of 50 feet or more.
If you do alot of SACD or DVD-audio, that would justify some heavy wire. :)
N
Nick diablo
Bi-amping can bring substantial benefits, especially when using an active crossover between the pre-outs and the power amps. The gains with passive bi-amping can be very worthwhile in many circumstances.
I have never seriously believed in bi-wiring. However, when re-organising my HT setup a few weeks ago, I took the opportunity to install two runs of wire to my my fronts.
Listening to the bi-wired output, it seemed better! I thought I must have been wrong about bi-wiring, even though it is illogical that it could seem to sound so different.
I determined to find out if what I thought I was hearing was correct, so I put in a switch system which would re-instate the connections between the two sets of terminals on the speakers, thus negating the bi-wire.
When I tested the system without knowing which setting it was on, I found that I couldn't tell the difference. All psychological/psycho-acoustic. :eek: :rolleyes:
At this point, you may be assuming that I'm partially deaf. :) However, I get better than average scores on such things as PCABX tests .
Even if you can get great scores on some of those tests, it's probably still not worthwhile bi-wiring rear speakers!
Regards,
diablo
