I am considering speakers (Dali Ikon 7, or may be Dali Ikon 6) that specify
Recommended amp. power [Watts] min 25
Recommended amp. power [Watts] max 200
In this case, what is the power in watts recommended? I would use them in a room that is 20ft by 30ft - my listening position normally would be 9 -12 ft from the fronts. With that kind of distance, the SPL levels would be different than what they would be if I stick my ear close to the speakers. On a normal day, I would not hear at very high SPLs, but once in a while when I want to take it to high volume, it should not die mid way.
Of the following two options which one do you recommend:
Option 1 - I buy 3490 (120x2) along with two fronts. Buy a 5.1/7.1 later when I buy other speakers for 5.1.
Option 2 - I buy 254 now, use them in stereo till I buy other speakers. But 254 may not have adequate power for the fronts.
Option 2 may turn out to be cheaper in long term if I can biamp. Will turn out much more expensive if I have to buy extra amp for fronts.
Based on the specs of the 3490:
Stereo Mode :
Continuous Average Power (FTC) Per Channel : 120 Watts per channel, 20Hz – 20kHz @ <0.07% THD, both channels driven into 8 ohms
150 Watts per channel, 20Hz – 20kHz @ <0.2% THD, both channels driven into 4 ohms
and the 254:
Stereo Mode
Continuous Average Power (FTC) per Channel : 65 Watts per channel, 20Hz – 20kHz, @ <0.07% THD, both channels driven into 8 ohms
Seven-Channel Surround Modes, Power per Individual Channel,
All Channels Operating at Full Power :
Front L & R Channels : 50 Watts per channel @ <0.07% THD, 20Hz – 20kHz into 8 ohms
I recommend you go with option 1. If I understood correctly the 3490 can be used as a power amp so it will not be totally wasted if and when you are ready for a 7.1 system. Even if you bi-amp, the 254 will likely not do justice to the basically 5 to 6 ohm rated speakers.
By the way, I read a review that suggested you use a subwoofer with those speakers so if you find that you are not getting enough base do not blame the receiver too soon.
