zumbo said:
I am sure you are educated in this field, but I am not so clear on your knowledge. If what you say is true, then why would amp companies offer a (125 x 2+) & a (200 x 2+) if there is no difference?
Not trying to argue. Trying to learn more.
Learning is good. We are far from arguing
Why not? Obviously marketing has something to do with it. A different speaker load will have something to do with amp choice. A different sensitivity speaker need different amounts of power, right? A 3dB difference in sensitivity needs twice as much power just to sound the same.
Many years of marketeering has something to do with all the amps. Cost differences? Some want a less expensive from a line that will just meet their needs. If you like it loud and I like it average or softer, we may need different amps? I may want the lesser amp, you may want the bullet proof, but, in the end, see below
What I said is that if you do not exceed the amps design limits, obviously if you clip one amp and not the other, one will sound different at that point as you exceeded the design limits and not the others, right? When you compare, you cannot exceed the weaker amp, levels are matched to close levels, 0.1dB spl.
But, I could be wrong. However, only credible DBTs will convince me of that
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
