Don't take it wrong, Pell, but you didn't experience any audible difference with a biwired speaker. You think you did because you felt good about it but the reality is that biwiring does absolutely nothing to the sound of a speaker system and that's a scientifically proven fact, not an opinion.
Bi-amping might help in some fairly rare circumstances but usually makes no difference at all in a typical home theather environment. Home theater is intended to be used with a powered subwoofer. While the powered subwoofer isn't necessary, it is still an integral part of way systems are designed to be put together. The powered sub removes the very great majority of the amplifier's power requirement. Low frequencies need way, way, way, way more power than the mids and highs. So, if you use a powered subwoofer, almost any kind of amplifier should take care of the rest and, in my experience does so in my typical home theater in an 18X22 room.
If you don't use a powered sub and you have a listening room that is far larger than is typical in a home, then you might need the additional power. The reason I recommended against it is that you are doing the project just to experiment, not because you have some valid reason to believe it will improve the sound of your system.
