Bi-amp limitations?
bandphan
bandphan
Well I do both presently in my system, and to my good ears, it sounds better
than without! :)
ok, but i bet dollars to donuts that no good ears can tell bi wired from not, and as i said in some cases bi amping does work(but id just prefer a bigger amp unless I designed the speaker and crossover)
DD66000
DD66000
who said anything other than that, ive not seen a post with an active crossover mentioned, and unless used that is passive biamping;)
This was my comment; Even bi-amping is really not worth the bother, unless one is really experienced with using external crossovers, and EQs.
Read external as active
Using an amp with enough power(220w amp or more) to drive the bass/mid-bass drivers will provide a much better sound than using a 110w receiver that is bi-amped. It takes very little to drive tweeters and midrange, and bi-amping would still only provide 110w to the woofers, using that receiver.
But using a 220w amp for the entire speaker would provide almost twice the power to the woofers, compared to the 110w receiver.
santeini
When you said both speaker,i assume you are talking about a pair.If this is the case than you wont have any problem to biamp. And since your speakers are rated at 8 ohms don,t worry about the impedance going lower during usage,because your amp should be able to handle it.
wolven99
wolven99
I found a webside with some info:
http://www.howtodothings.com/electronics/how-to-bi-wire-home-audio-loudspeakers
I noticed in the owner manual for Paradigms that they recommend connecting to the same prongs on the receiver. So, 4 prongs on 1 speaker & 2 prongs on the receiver.
However, in the manual for my receiver the recommended connection for a speaker is 4 prongs on 1 speaker & 4 prongs on the receiver. Thus using both A and B speaker connectors.
bandphan
bandphan
One is bi wiring and the other is bi amping. :eek:
Here is a good website that will not only explain how to do them but how not to:eek:
Audioholics.com
