Hello!
I currently have a speaker setup that's primarily used to stream movies and shows and I'm considering expanding the setup to provide a better experience (particularly for movies).
My current setup consists of:
- Polk Audio Monitor 70 Series II Tower Speakers
- Polk Audio TSi CS10 Center Channel
- Sony STR-DH800 7.1 Channel AV Receiver
- LG OLED55C9 TV
My current room specs:
- Concrete floor and ceiling, steel stud walls covered with drywall, and floor to ceiling windows
- The room is very open to the rest of the house, with windows on two sides (adjacent and opposite the TV) and a wall behind the TV
- The size of the room itself is 12' x 11 1/2', with the footprint of the speaker and couch layout taking up 9' x 11 1/2'
- Surround speakers would have to be placed on stands as there are only walls of windows adjacent to the couch.
I don't have the sensitivity to audio to really appreciate spending a lot of money on the components, but can certainly still appreciate quality over cost. My spending habits tend to land in the "the best value product in this category" range, at the time of purchase. All of my audio equipment is around 10 years old now. To use car stereos as an example, I might spend $1,000 to upgrade an OEM stereo from a 4/10 to a 7/10, but I wouldn't spend another $1,000 to upgrade it from a 7 to an 8.
I'm debating purchasing a relatively inexpensive set of surround speakers and subwoofer to complete a 5.1 setup, but I'm really curious if "something is better than nothing"? The products I've been looking at are very entry-level, with the intent of filling out my room and adding a bit of bass (and not necessarily to "upgrade" the overall sound quality).
For surround speakers, I've been looking at:
- Polk Audio S10 Satellites
- Polk Audio T15 Bookshelf Speakers
And for subwoofers, I've been looking at:
- Polk Audio PSW10
- Polk Audio PSW111
I live in Canada so speaker selection is a bit limited (or... the price of importing makes certain selections a bit cost-prohibitive), but I'm definitely not trying to stick with Polk for any other reason.
Would filling out my setup with the above be "better than nothing"? Or how compelling would your argument be to go with better surround and subwoofer options? I've looked at subwoofer options from BIC, SVS, or RSL Speakers, but each is a jump in price ($500- $800 Canadian vs around $200 for the Polks). I'm not sure what other options would be decent for the surrounds on their own - would love to hear some for you guys.
I don't really have a budget to provide - just keep in mind my spending style as mentioned above. It would be easy for me to drop $400 on the sub and surrounds if they were going to be as good as the system I already have, but if there is an argument like "spend more than double to receive more than triple the quality" kind of thing, I could be persuaded.
Thanks in advance!
