better for music SVS pb12-nsd or HSU vtf2
Pete_Hsu
Thanks speakerman. Do you think the VTF2,3 for $500 is acceptable to your 3,3? Or, is the extra $130 worth the money?
roger, don't forget that after shipping, even with the current -3 Mk3 sale, the -2 Mk3 is about $180 cheaper. That is a pretty significant difference. If budget is tight, and/or if room size is less than 4500 ft^3, then -2 Mk3 is a great performer!
Sincerely,
Pete
mike c
mike c
Has TOO much money and time :eek:
what a nice problem to have :D
i can save you from such misery major, bank acct no. 1234-5678 :D
what happened to Peter's old login account, did he forget the password?
Pete_Hsu
mike, I wanted to use a more standardized login name for the company. So it could be Dr_Hsu, Pete_Hsu, Leo_Hsu, Candi_Hsu, etc. Also, my private message boxes were all basically filled up, so it gave me good excuse to just start over :D
majorloser
majorloser
Moderator
Consider the old account closed, then.
Pete_Hsu
Thanks ml!
Hope you are holding up well with your dual -3 HO/t's + MBM-12 :)
Sincerely,
Pete
Welcome aboard:D
Are you related to Dr Hsu?
croseiv
croseiv
Not to stray too far OT, but that Epik Conquest is a beast. And the price ain't to bad...:eek:
Davemcc
Davemcc
At various times, I have alternated between the PB12-Plus and the STF-3. In my experience, if I were looking for a sub primarily for music, I would choose the Hsu. Bear in mind that this is just my subjective opinion and not backed by science of any kind. Nor is it a slam on the SVS, which is a very competant sub in it's own right and would surely not disappoint.
abboudc
The only way to really tell which one sounds better to you is to listen to them both. See if you can find someone in your area and go audition them.
Flatness of response is a preferable trait. Most good subwoofers (and certainly the ones you're talking about here) have fairly flat responses. But they do sound different, despite their relative flatness.
furrycute
furrycute
It's one thing to be able to play loud, it's something else entirely to be able to play the same note with minimal distortion. A "musical" sub produces minimal distortion even at really high SPL. The Velodyne DD series of subs use a servo feedback mechanism to minimize distortion, typically giving you less than 1% distortion.
Budget subs don't sound good, partly because they sacrifice accuracy (low distortion) to attain high volume.
