Better 2-channel amp than the Behringer A500 for the price?
Crackerballer
Crackerballer
Lulimet
Lulimet
If it were me, I would go with the QSC because I've had QSC amps in the past and had great experiences with them.
ahblaza
ahblaza
I just ordered the Crown XLS1000 from Guitar Center. For the price (with coupon code) it was hard to beat. $266 shipped to my door, and has better specs than the A500 and iNuke. Also, reading many reviews on it, it apparently also runs very cool and is super light. Once I get the new Polk system setup and this wired with them, I will give a full report.
You are welcome for the heads up with the code for the Crown XLS1000!!!
F
fokakis1
I'm running a pair of Polk Rti-a9's off the Behringer EPQ 2000 (700 X 2 @4 ohm/500 X 2 @8 ohm). The fan is loud (which you don't mind), but it has rca inputs and sounds fantastic. $299 @ PE or bestbuy.com
Why didn't you tell me a week ago:mad: (I know I know I didn't ask)? For whatever reason I thought Mono and Blue Jean costs were comparable and I ordered my last pairs from Blue Jean then made a fatal (just painful) mistake checking on the Mono prices a day after. Anyway I think Blue Jeans sound better, I mean the click sounds very crisp, crystal clear, nice transient/immediacy..:D
It's coming, it's coming. I've owned a set of Paradigm Studio 20s before, so I know these Polks aren't even close to a quality speaker. But for the price, they will do me just fine until the wife and I build our next next year or 2014.
Congratulations! I am sure that Crown amp will sound amazing even with the Polk monitors. That Grant knows his stuff, but even if I go by published specs I would still think the Crown you bought is a better amp than the UPA-2.
By the way, Polks aren't really so bad but people do sometimes exaggerate things on forums to make their points and started those hearsays, that eventually turned into "facts" (often stated as..). I really doubt the Studio 20 are that much better either, better for sure though but both can sound quite acceptable in HT applications.
Crackerballer
Crackerballer
Guys I really appreciate all the input. Ahblaza I gave you some reps for the coupon code, it was a big help. Also I ordered the cables GranteedED suggested. i have some pretty good speaker wire already. Again, I'll give full reviews on the amp and speakers when they come.
GranteedEV
GranteedEV
Well I am glad I ordered the Crown, because I just saw this:
http://forums.audioholics.com/forums/deals-deals-deals/78184-smoking-deal-emp-e55ti-towers-limited-availability.html
So I ordered them and the large matching center! Those E55ti's will be AMAZING. That price is crazy, I can't wait until these arrive!
It took some experimentation with placement, and livening up of the room, but once I got things dialed in, the E55Tis throw a huge soundstage. Rather different from the Paradigm Studio speakers though.
Crackerballer
Crackerballer
I am ok with that. I have the 30 day audition on them too. My Paradigms have been gone for 6 years now, so I can barely remember what made them unique. Either way I know these EMPs will be a good speaker that can last me a long time.
L
lucasamiller
I have a Crown XLS 2000 for subwoofer duty and it's an amazing amp. I don't even think the fan has came on yet, unless it's that silent.
The only thing about it, my low grade Sony AVR could not push enough signal to the Crown. I had to purchase an Art Cleanbox PRO from Parts Express to boost the signal. After boosting the signal and firing it up for the first time, it was so loud, it knocked two picture frames off my wall.
Just a heads up in case it happens to you.
Here is my setup
Sony AVR > RCA > Art Cleanbox PRO > Balanced XLR > Crown XLS 2000
Crackerballer
Crackerballer
Thanks man. I am sure my Onkyo is up to the challenge, but I will keep that in mind if I set it up and it seems to be lacking.
HexOmega
HexOmega
Just wanted to share a recent Crown XLS experience:
I purchased one XLS1500 at the Millbury, MA Guitar Center on 01/16/2012. The in-store sale price was hard to pass up ($340) and their return policy is fairly liberal, so I figured it was worth a shot.
To keep this post entirely objective, I will say nothing about my opinions regarding sound quality. Moving forward, I had a few issues:
The pre-amp outputs on my Yamaha RX-V667 receiver were not quite hot enough to drive the Crown amp without cranking the Gain adjustment. At ~75% gain, there was still a 6dB mismatch between channels (which I was able to even out using the YPAO parametric EQ). At this higher gain level, I easily heard more "noise" from my Mirage speakers at idle which was not present using the amplifiers in my Yamaha receiver. This of course was not a "fault" of the amplifier necessarily.
What WAS a fault of the amplifier was that the channels were not level-matched side to side. I attribute this either to the gain controls, which did not have matching detents, or a faulty output transformer in one of the channels. With the gain controls matched as closely as possible, and the pre-amp outputs on the receiver set to identical values, I consistently measured the right channel 2dB lower than the left.
Otherwise, the Crown ran extremely cool during extended high-volume playback and remained very quiet otherwise. The fan on the rear panel turned on once or twice, and was inaudible from >3 feet away.
Guitar Center was very understanding of the issue and took the amp back without pause; thankfully I was not charged the customary 15% open-box restocking fee.
derrickdj1
New amp
Ever consider the used market. There are some nice amps that one can buy for the same money. Do you want a rack mount amp. I have 2 vintage Yamaha M 70 amp in great working and cosmetic condition. $200 -$400 dollars. They fit into a console, no noise and heat is not a problem. 200-400 watts.
