Bet receiver music setting for mp3
stSpringer2003
stSpringer2003
Onkyo TX-SR507 5.1-Channel Home Theater Receiver
What music setting on onkyo receiver is best for mp3's
thanks
markw
It's your ice rream cone and you get to choose the flavor.
thanks
Whatever sounds best to you. Me, personally, I like plain vanilla (stereo)
dapack69
dapack69
Does your receiver have Neural Digital Music like the 1007 does?
Neural Digital Music is a new surround mode specifically designed to enhance the playback of compressed digital music content. It provides listeners with an expanded sound stage and clean surround experience, even with compressed audio sources such as MP3s and Internet streams.
ju10503
Not the answer you want, but mp3s are good for portable mp3 players at best. Playing mp3s through an even half-decent setup is asking for disappointment unless you don't care much about fidelity.
stSpringer2003
stSpringer2003
My onkyo Receiver Music Choice Settings:
Music Choice Settings on CBL/SAT
Dolby D
Orchestra
Unplugged
Studio Mix
All Ch St
Full Mono
Direct
Stereo
Music Choice Settings on DVD/BD when playing MP3's
Surr Sens M
PL II Music
Neo:6 Mus
Studio Mix
All Ch St
Full Mono
Direct
Stereo
Thanks
lsiberian
lsiberian
That is assuming he didn't rip them at a high bitrate and he's listening to a very well done classical recording.
Properly done ABX testing shows no audible difference can be discerned between most high bitrate mp3 tracks and cds(see hydrogen audio for more information). I've heard there are only a handful of recordings that actually have a supposed difference, but they are are usually pretty obscure.
For your standard 90s and 00s rock mp3s do just fine. Just use the highest bitrate possible. ;)
Dolby D
Orchestra
Unplugged
Studio Mix
All Ch St
Full Mono
Direct
Stereo
Surr Sens M
PL II Music
Neo:6 Mus
Studio Mix
All Ch St
Full Mono
Direct
Stereo
Thanks
Try them all and make note of the ones that sound best. Using the Cable/Sat input for the MP3 player won't hurt anything, so you can try the ones that are different. If you hear something you don't like, find out if ripping those songs at a higher bit rate helps. If possible, use .wav or FLAC (PC) or AAC (Apple). These are all lossless and will cost the least in terms of sound quality.
JerryLove
JerryLove
Once you find the perfect one, try the next MP3. Unless you are very compressed, you'll likely find the mastering differences more signifigant than the compression effects.
lsiberian
lsiberian
Ultimately it's the quality of the mastering and song itself that makes or breaks it.
