Best Way To Run A 30ft dvi-d signal
E
Everydaydiesel
I want to extend my lcd monitor that uses dvi-d cable 30 ft from the source.
What is the best way to do this while maintaining the picture. The resoultion is 2560 x 1600
E
Everydaydiesel
Thanks for the reply, but I wonder why they stop at 19xx resolution?
Do I have to get the vizionware cables? what happens if I try to run the fiberoptic cables?
Im not looking to have the picture perfect...but I dont want the picture to be so blurry I cant read it.
500$ seems like alot for a cable but if I have to have it............
majorloser
majorloser
Moderator
I know that VizionWare has some of the highest throughput available on the market. You can always send DVI Gear an e-mail and ask them.
The bandwidth you're asking for is HUGE. Even more so if you want 60Hz or higher.
majorloser
majorloser
Moderator
Give DVI Gear a call or send an e-mail. You're going to need a dual link DVI-I cable.
E
Everydaydiesel
Thanks for all the help.
I was able to get a EXT-DVI-141DLB for 99 bucks and I picked up a Gefen Dual Link DVI Cable 30 ft (M-M) CAB-DVIC-DL-30MM for 144.
Excellent prices on both items and it should work great. Now I just need to find 30ft USB cable and 30ft ps/2 cables.
Thanks again.
majorloser
majorloser
Moderator
Thanks again.
That's simple. Send the USB over Cat5 cable:
http://www.cablestogo.com/product.asp?cat_id=1521&sku=29341
Long PS2 cables:
http://www.cablestogo.com/product_list.asp?cat_id=920
