Hi all, first time poster but long time audio lover. I bought a pair of JBL EON 615 PA speakers and I am trying to figure out the best way to hook this up to a new 7.2 Denon Receiver (at work or I would have the model #). Right now I have these beasts hooked up to the front headphone jack with a couple of splitters. This works but I am thinking about adding some additional speakers to get the surround sound going which leads me to a couple questions:
1. What type of cables/connectors would you recommend? The speakers can use either XLR or 1/4 and I am currently using two 1/4 instrument cables (one for each channel), but I just read somewhere that you should never use instrument cables... I would prefer to get to banana plugs to the receiver, but I am not sure if the RCA connectors are just as good.
2. Since these speakers are self powered, any concerns there hooking it up to a receiver that expects to be powering the speakers? I am open to getting a mixer if that would be better and find a way to hook up the mixer to the receiver, but I am assuming that will lose any Atmos or Dolby sound output.
3. I am not exaggerating with the use of beasts above and even with speaker volume settings, do you think regular home theater speakers will have a chance to be heard with these? The review I read that convinced me to buy these speakers said they melt faces....and I can also say that is not an exaggeration. For example is a sound bar even going to be worth it here, ie will it not get drowned out by these?
I was also considering just leaving these for stereo music play and get a normal home theater package for the surround sound, but I love these speakers too much not to try to incorporate them with the surround. Thanks in advance for the help and any suggestions you may have!
