Different subwoofers have different strengths, so you can't really make an absolute list without a more explicit criteria. For instance, the BIC can probably get louder than the STF2 at certain frequencies, but the STF2 is a more linear performing subwoofer. It will have a flat response whereas the PL-200 has a peakish response, so the STF2 is a more accurate sub.
Same thing with the XV15 as opposed to the Outlaw, SVS, and Hsu subs; yeah, it gets louder in some frequency ranges, but at the expense of linearity.
As for those rankings, even if you go by using Steve81s table, which I wouldn't, the VTF2 is a higher performer than the PB1000. The Outlaw sub is going to outperform it as well. The PB1000 would likely be behind the VTF2, LFM-1 Plus, and Rythmik LV12 with regards to performance. For $500, the Premier Acoustics PA-150 is a bargain as well. It doesn't quite dig as deep as the VTF2 and PB1000, but its mid and especially upper bass output blows those subs away. It's upper bass output even surpasses that of the PB13 Ultra, although it doesn't play quite as cleanly. Again, it's frequency response is decidedly not the most linear.
As far as sealed subs go, you seem to have grouped the XS15 in with the ported subs. Some other great options would be some of the parts-express subs, namely the
Dayton Reference 12", the
Dayton Titanic 12", the
Titanic 15", and the
Dayton dual 12". What's really nice is, if you are willing to do the assembly yourself, a very easy project, that shaves $150 off the assembled prices: check them out on
the subwoofer kits list. For sealed subs, I am guessing those kits are by far the best value out there, unless you go all out DIY.
