It appears you are expecting to much from a $500 budget.
So you're saying that first sentence right up there ^^^ didn't mean that you assumed my entire budget for a 5.1 or 7.1 surround setup with receiver was $500
My goals were not clear enough? Really?? Could I have made it any more simple... Let me break it down a little more. I want loud crisp bass with as little distortion as possible for my budget, and I want my rear speakers to make loud noises.
Dude I think you need to take a pill or have a drink..... My only point was we as a team are trying to give you advice for
FREE!!!! And you have stated your expectations and never aluded to a budget max or how much equipment you expected to get with $500. Now you have a budget of $1500. Do you still need a BD Player with in that budget? Do you need cables and speaker wires with in that budget. My guess is YES since you are looking into HTIB options how can we give you good advice if you have not explained your PLAN. And with out a PLAN you will not be succesful in your endeavor.
My real point was if you treat people like S*** you won't get any help!!!!
And I still stand my my statement you can not get what you want with your budget!!!!! You need a minimum of $600 for a sub likely closer $1000 to get the bass you are looking for, just because you do not want to hear the truth you get all defensive.
