best sceen for JVC DLA RS1U
mathman
hi,
we're leaning toward the JVC DLA RS1U projector, but are unsure on the best screen. here are the details:
  • located in the basement with 9.5ft ceilings
    expected seating distance is 10-12ft to screen
    will have light control near screen but behind seating area (greater than 12ft to screen) is wetbar/pool table so lighting not as controled at times
    room will be painted realtively dark
    budget is $1K-$1.5K but only if i have to spend that much
by the way, any reason i wouldn't/shouldn't use the denon 4808CI AVR and 3930CI DVD player with this projector?
thank you for your time!!
avaserfi
avaserfi
This weekend I got to see a Carada Brilliant white screen and was very impressed. You could give them a call and see what they suggest.
Also, if you are in the market for a good quality acoustically transparent screen, dirt cheap compared to the others out there, check out this place I also got to check out one of these screens this weekend too and it looks great.
