Best Satellite Speakers for X1500H denon .
ashrithashi90
Hello ,
Can anyone suggest me a good pair of 5.1 satellite speakers ??
Thought of JBL sub woofer .. and confused with satellites. So plz refer ...
I love watching surround movies 5.1 tracks , DTS-HD , want a good rear speakers fr overall surround .
Thanks in advance .
Sent from my SM-G975F using Tapatalk
What is available to you where you are? What's your budget? You want equal speakers for the 5 channels? Subs, you want more than one? Seems from your other thread you have a very minimal budget....
ashrithashi90
Yes got a minimal budget . Since I'm entry level to AVR.
Does harman speakers do good in detailing sounds. ?
ashrithashi90
I need 5.0 satellite... 1 sub ..
Later after 6months will try adding more.
Book shelf speakers better or satellites ?
