Best pre-amp/amps for my system........
Cheapshot
Cheapshot
Im trying to decide on equippment for a system setup in my room (12' x 11'). I just bought a pair of paradigm reference 60 v2.0's for $650 and still need to by pretty much everything else.
For the setup im planning on right now I would still need to buy two more bookshelf speakers ( thinking mabye reference 20's), 15' sub (not to sure what type yet), turntables (1200's), mixer (not sure yet), amp, and pre amp.
I want to be able to run the tables, a cd player, and computer off the speakers w/o having to switch cables or anything like that.
The refernce 60's i have are rated for up to a 200W amp and I plan on getting an amp of that rateing (if not very close to 200W). The sub would most likely have its own internal amp so I'm thinking the amp (or amps) will need a sub out also (let me know).
Im hoping theres someone with a similar set up that can help me out with what to look for in an amp/pre-amp (ie: brands, # of channels i need). If there's anything to worry about as far as compatablility for mixer's/amp's some education would be so clutch right now too.
This setup is for personal use only im not going to be doing any shows or anyting with it. The plan is to eventually have my own studio where i can do anything i want (mix, make beats, scratch...whatever) so it durability is not a huge consern w/ the speakers and sub.
I know more info is probly needed to recommend all this equipment so just ask.
If theres anyone who thinks they know what I'm looking for,or have a setup similar to the one I've described holla at me cause I need help figuring out whats right for me.......thanks
Z
zumbo
This is basically a DJ set-up?
You have no plans for HT?
