best lcr speaker under $200?
mercurylines
hello
i recently purchased a samsung 42inch plasma and i need a pair of lcr speakers to go on each side. i'd prefer something about 20h"x5w". any suggestions? i really can't go over 400 bucks for the two speakers as i just bought a house and need about 900 other things. your help is appreciated
thanks.
m_vanmeter
you might try this set from frys.com
search for Polk RM6750B
bass addict
I'm biased as everyone knows, but I would also look at the Axiom M22's. :) I know they are a little over budget but worth looking at nonetheless.
Soundman
Soundman
Have you thought about Ascend 340 SE's? I know they are a little over your budget, but they are 21"H X 7.5" W, just a tad wider then you were looking, but not much.
