Buckeyefan 1
AVRat,AVRat said:The Rti 12s would appear to be comprised of the Monitor 40 system with the addition of the woofer section. The Monitor 40s have a power rating of 125W, while the Rti 12s are rated at 500W. The Rti 12s upper section is alleviated of frequencies below 120 Hz which we can now assume handles about 100W. Given this, it would appear that the woofer section handles 400W. At the ratio of 1:4, and with the Yammy providing 130W, it looks like you would need an amp rated at about 500W for the woofer section to provide proper balance.
I would still go with a good 2-channel amp to power the whole speaker and let the crossover network take care of appropriate power distribution..
Good point. Way to break it down. He still has the issue with brightness, but with that setup, can slide in an eq to tame the highs. An eq would be perfect in that sense because he can get rid of the muddiness, and bump the lowest frequencies for some extra bass.
