best active subwoofer in Italy
Danzilla31
Goo
Oh sorry for not replying i had no time
Thank you a lot guys
I just looked at all the links you gave me and now i just need to choose or find a good deal
Actually my birthday it's on the 30th of September so i think i'll get it some weeks earlier
Good luck with your choices hope you find something that makes you happy!
piefadase
Hey there i was browsing the internet to find some reviews of the auna linie 300sw ; i didn't find much but i found a sub that looks interesting do you think it is any good? I can't send the pink as this in my 4th message so i'm sending it in another one
Danzilla31
Well first question what's your budget range and does this sub fit in that budget? If it does I'll look it up and see what it can really do. Second question what are you expecting out of the sub is it for music or movies. If both what % for either say 30% for music or 70% for movies basically what are you going to be using it more for? Lastly what Kind off setup are you trying to do a surround setup like 5.1 7.1 etc or for music listening or 2.1? Are you starting off on a tight budget? Will this be like a starter system you plan to upgrade later? Knowing these things will help when anyone looks at the sub specs and tries to determine if it's a good sub for you to look into
afterlife2
afterlife2
Sorry but it won't work because you need to attached speaker wires and this one does not have one:
You need one that has these 8 RED/BLACK IN/OUT clips:
I still think you should get what I suggested Mini Amp/Speakers and get a used subwoofer from Craigslist. Give me a link to craiglist and the city in Italy you search in and I will look for you.
Danzilla31
Looks like you got some great help from people that already know what you need I gotta say I think afterlife2 is spot on man I have scored some killer deals on Craigslist on speakers and subs when I was budget shopping. If you got somebody helping you look at the deals on Craigslist you can't go wrong usually.
piefadase
So it will be a 2.1 system 95% for music and 5% films (i watch them occasionally)
My budget is under 150€ for a subwoofer
afterlife2
afterlife2
I tried but nothing came up under
altoparlante, sostantivo, maschile, etc.
I still think this is good for the price $139.92 United States Dollar. Reviews are good in Amazon Italy/UK. If you don't like it(doubt it) you can send it back to amazon: https://www.amazon.it/Auna-linie-300-sw-bh-Subwoofer-Attivo-colore/dp/B06WWBC5YG/ref=sr_1_5?ie=UTF8&qid=1532709898&sr=8-5&keywords=home+subwoofer&th=1
In white ((($128.25))) United States Dollar:
https://www.amazon.it/Linie-300-SW-WH-subwoofer-amplificatore-integrato-ingresso/dp/B014RJZWVQ/ref=cm_cr_arp_d_product_sims?ie=UTF8
Demo:
Danzilla31
The one afterlife2 just sent you to look at since you want 95% music looks very good for that price it fits your budget too I would go with that one if you can
piefadase
Thank you
Actually the auna subwoofer captured my attention because it looked pretty cool for the price range
The only thing i am skeptical about is that the only info i could find online were people asking about the quality of the sub and receiving answers like: "i don't know, it's a bit too low the price. I think auna is a rip off. I' ve never heard of auna" so idk
However I think i'll buy it (i'll let you know before i do)
afterlife2
afterlife2
Welcome. Some people are just not reviewers. The ones that go into detail are the ones you wanna read. I'm sure it will exceed your expectations. Too bad they don't sell them in the US(auna Linie 300-SW-BK subwoofer & Scythe SCBKS-1100 Speaker) I think you should get the Auna.
Danzilla31
Thank you
That subwoofer that afterlife2 sent you with the YouTube review is superb for its specs you are getting excellent bang for your buck I seriously doubt that you would ever regret purchasing it I'd get that one if I was in your shoes.
piefadase
yeah i'm pretty sure i'll buy it in the next few days :D
Sheep
Sheep
Oh no, I was just using it as an example. I run dual Velodyne's.
SheepStar
