jaxvon said:
Let me also say that you should budget for a better sub than the Acoustech system has.
Absolutely. I think the one major decision I have made since I posted was to go with a HSU sub (prob the VTF-3 Mk2). I am greatly comforted by the ability to add the turbo down the road if I want more.
jaxvon said:
As for a receiver, the refurb Yamaha would be a good choice. If you can pick one up, go for it.
Sadly, I don't see it anymore. Right now, I am not aware of any other great deals on the popular 7.1 receivers (Panny XR55, Pioneer 1015TX, RX-V2600, Denon 3806 or the HK whose model # I can't recall). I am still researching what features are offered by the pricier models that I might want. So far, Auto Room EQ and extra inputs are the only ones that seem like something I would use.
jaxvon said:
Also, don't forget to budget for cables, cable organization stuff, and other accessories (new DVD player?).
No worries. I don't have a strict budget, I just picked $1500ish as a place to start with. I also figured that since I don't have a fine ear and won't be listening to music, I would be over-spending if I went much higher.
I might pick up an Oppo somewhere down the line. I need to do the research and see if issues like macro-blocking are likely to affect me. It's low priority, though, since my HD PVR has largely seduced me away from DVD's =)
jaxvon said:
And since there's no WAF, I think you should look into some DIY room treatment. It's one of the most cost effective upgrades you can make.
Already on the "to do" list ! Great suggestion, though !
