BenQ W1080ST and 2.35:1 vs 16:9
G
gwidion
Hello everyone. I am new to these forums and have a question about screen aspect ratio.
I plan on buying the projector above. The majority of the time I will be using it to watch Blu-Rays. I have been reading that, since most movies are filmed with a 2.35:1 aspect ratio, I should purchase a 2.35:1 screen. This projector information says that it displays in a 16:9 aspect ratio. Will this be a problem if I get a 2.35:1 screen, or can I adjust the image?
Thanks for the help!
BMXTRIX
BMXTRIX
Where have you read that you should get a 2.35 screen?
Were they talking to you? Or were they talking to people who have a lot of money to spend on their dedicated home theater setup?
Many movies are NOT shot in the 2.35 aspect ratio. Almost all games are 16:9 (1.78 aspect ratio), many movies are 1.85 aspect ratio, all HDTV is 1.78 aspect ratio... And most of all, the projector itself is 1.78 aspect ratio (1920x1080).
So, why is it again that you want a 2.35 screen?
When people are just getting into front projection they read a great deal about the 2.35 aspect ratio. There are tons of ads around 2.35 as well. It seems ideal, and is definitely cool. Ah, heck - it is cool! All you need to do it properly is a projector with motorized zoom presets, a room which supports a good 2.35 screen, and you are good to go. Well, except almost no projectors have motorized zoom presets... That's okay, you just need a good anamorphic lens and a lens sled. (several thousand dollars!)
What!?! Yeah, a good anamorphic lens is expensive, and the 'poor mans' zoom method is well beyond the capabilities of the W1080ST.
What you want is a 1.78 screen.
How big is your room? How far will you be sitting from the screen? How much conditioning of the room are you doing? Dark walls, ceiling, carpet? Sound treatments? Why the short throw 1080ST over the W1070? Why not the Sony HW40ES? Ceiling height? Room dimensions? Surround sound? Screen type?
There are times when I recommend a 2.35 setup, but they are far and few between. The 'poor mans' zoom method, as used by some projector owners is fine, but they could run a 16:9 screen of the exact same width, and have just as much of an appealing image for 1.78 content at the larger size.
Perhaps you should look into a screen with black 'snap-on' masking panels for 1.78 to 2.35 viewing conversion if you want to have a properly masked 2.35 image.
But, with the 1080ST there is no real way to properly get good 2.35 projection from it and still have a usable 1.78 setup, which will be needed.
G
gwidion
Thanks for the help. Considering what you said, I will probably go with the 16:9 screen. The reason I am going with the short throw projector is that I have a ceiling fan in the middle of my room, so my only option is to mount the projector in front of the fan. A short throw would be the only option for me. I will most likely get a 100" screen.
The room is already set up, and I already have a sound system. The only thing I need is the projector, mount, and screen.
BMXTRIX
BMXTRIX
I would definitely stick with 1.78 on the screen size for your setup and the W1080ST is a very solid model.
I would get a really good mount so you don't have issues with projector drift or headaches with aligning it or getting the height correct. The Chief RPMAU (or any Chief Elite mount) is what I recommend. The Peerless PRG-UNV is a good mount as well. I've seen almost no other mounts which I think are very good.
The Elite Sablescreen is a good entry level fixed frame screen for a reasonable price via Amazon. Definitely one to check out.
Bella
This is extremely pleasant and nice post.....you shook posting it.....thanks a great deal for posting it...!!
________________
Johni
