Belden 5000UE vs Canare 4S11
RichardinIdaho
My new Pioneer Elite vsx-30 allows for Bi-Amp wiring using the back surround amp.
Can I use the Canare 4S11 to Bi-Amp or does it just work to Bi-wire?
If the answer ti the above is yes, would it be best to use a singe run of the Canare or two runs of the Belden.
The runs are under 10 feet. The cost difference at Blue Jeans is less than $5.00. So that is not an issue.
Reply With Quote Multi-Quote This Message
adk highlander
adk highlander
Sith Lord
The 4S11 will work just fine for Bi-amping or Buy-wiring. Very nice quality cable.
Yes, 4S11 is what I use and it is great cable. What DOESN'T work is biwiring :)
