jeffsg4mac said:
Thanks Chris for proving my point. 1/6th would be accurate enough to bring down the offending peaks.
I'll focus on just peaks, becuase you are make a point about peaks.
In this example, 1/6th octave.....
-Could not determine the frequency, Q or amplitude of the 25Hz peak.
-Could not identify the 37 Hz peak as existing.
-Could not determine the Q or amplitude of the 54 Hz peak.
-Could not identify the 93 Hz peak as existing.
-Could not identify the 117 Hz peak as existing.
The DEQ 2496's RTA is more accurate than the red line you have there anyway. No need of 1/60th resolution to calibrate a sub. 1/10th is plenty.
Indeed, you are correct. My analysis was working with even numbers, so I rounded to 20 sample points between 20-200Hz. The DEQ2496 samples at 21 points between 20-200Hz. However, this is not enough difference to amount to any difference.
-Chris
