mike c
that's crazy stupid.
I cancelled my order.
$349, with free shipping.How much are the 4000's going for on ebay?
There's a difference between input and output voltage....There are two things I can't understand...
the first: the MAX power consumption of the EP4000 is 2600w (a part that is the same of EP2500) so how can it give 4000watts? It shouldn't has a output bigger than the input...
second: what is this technology (ATR)??... the weight of the amp is the same and the power is declared with different factors...
I mean: -(a part that I've bought an EP1500, not a 2000 cause I think they're the same...)
EP1500 8Ohm 1kHz @0,1_%THD 280w
EP2000 8Ohm 1kHz @1___%THD 350w
you know from 0.1 to 1% there is an increase of 1dB, so 280x1.3=360
I really can't understand!
I wuold like to see a result of objective test to understand if there is any difference...
Yes but the output power can't be bigger than 2600w that is the max consumption... It should be 1300wThere's a difference between input and output voltage....
We only want to create power not energy.Increasing the voltage the Amperage goes down...you can't create energy
Ahh I got you. But how does that work.you have 2600w
220V x 11.8A
if you want 300V the amperage goes down at 8.6A
the power doesn't change
EP4000 is a relabeled EP2500.So what is the difference between the 2500 and the 4000?
