or for four A500's (and some lights) ... I did this: (I still have to turn it on manually, but at least it's just one button.)
ignore the short thingies plugged in, I made the "power strip" too close to each other to accomodate the giant (angled plugs) behringer power cables.
That's 28 amps. How did you get all the circuits to it? I would have used three to keep everything underrated. That is 1.84 KW of audio power. Now I consider that a significant engineering problem. That is similar to my system that has 1.7 KW of audio power.
Now I put a panel in the equipment chase, and have two circuits devoted to the amp case. Now the front left and right speakers use total of six amps on one circuit, delivering a total of 880 watts. Now I had to change to a slow response breaker as a standard breaker kicked out about half the time on switch on. These amps are switched from a 24 volt relay. The two center channel amps switch from another relay, the two rears from another relay and the four center back amps from another. This is so amps can be switched in according to listening requirements.
The illuminated switches can be seen in the fourth unit from the top.
http://mdcarter.smugmug.com/gallery/2424008#127077469
Here are the relays and extractor fan control.
http://mdcarter.smugmug.com/gallery/2424008#127077808
Now I felt the heat required fan extraction. So a Fantec fan was installed remote from the location, that vents to the outside. I also put in significant air conditioning into the mechanical chase.
Now the extractor fan tube was an insulated tube, but my tin man did not put enough insulation on it. We did not get much snow until the end of the winter last year. This year we have had significant snows since the end of November this year. The extractor duct caused significant snow melt and an ice jam on the roof. We added insulation last month and my builder was in the roof again today adding extra insulation.
So I think the problems of engineering for this much power are substantial.
The other matter is that most outlet circuits in American homes are shared with lighting. I think people planning for the sort of powers we use will encounter significant problems more likely than not, if they don't carefully plan and take expert advice. This sort endeavor poses significant engineering problems on multiple fronts.
