I just started building my first low budget sound system, after looking at some reviews i decided to buy the fluance speakers AV-HTB and now need to decide on the receiver but no idea what to get .
here is the specification for the speakers:
Front Floorstanding Main Speakers
System Type: 3 Way - 3 Driver Floorstanding Main Speakers
Tweeter: 1 inch Titanium Soft Dome Ferrofluid Cooled For Longer Life
Midrange: 4 inch Poly-coated Driver with Butyl Rubber Surround
Woofer: 6.5 inch Poly-coated Driver with Butyl Rubber Surrounds
Power Handling: 20 - 120 Watts
Frequency Response: 38 - 20K Hz
Sensitivity: 88±2dB
Crossover Frequency: 1000/3500 Hz PCB Mounted Circuitry
Impedance: 8 Ohms
Enclosure: Bass Reflex Design
Dimensions: 33.0 X 8.3 X 9.8 inches (H x W x D)
Weight: 27.3 pounds/speaker
Center Channel Speaker
System Type: 2 Way - 3 Driver Center Channel
Woofer\Midrange: Dual 4.0 inch Poly-coated Drivers
Tweeter: 3/4 inch Titanium Soft Dome Ferrofluid Cooled For Longer Life
Power Handling: 10 - 100 Watts
Frequency Response: 70 - 20K Hz
Sensitivity: 86±2dB
Crossover Frequency: 4000 Hz PCB Mounted Circuitry
Impedance: 8 Ohms
Enclosure: Acoustic Suspension Design
Dimensions: 6.0 X 16.2 X 6.6 inches (H x W x D)
Weight: 9.0 pounds
Rear Surround Satellite Speakers
System Type: 2 Way - 2 Driver Surround Speakers
Woofer\Midrange: 4.0 inch Poly-coated Driver
Sensitivity: 85±2dB
Impedance: 8 Ohms
Dimensions: 9.7 X 6.0 X 6.6 inches (H x W x D)
Weight: 5.5 pounds/speaker
I just need something with minimum of 100 watts per channel, budget not more then 270 $, don't care if it is 5.1 or 6.1, i know i am not gonna upgrade to 3 rear speakers.
I saw the following at best buy, which one do you recommand:
yamaha HTR-5830
Sony STR-DG500
HTR-5840BL
Please give me your advise and if you suggest anything else in my budget please let me know.
Thanks in advance for your help
