I was looking at the Bryston site. Any idea what the 300 w x 5 costs? I see it doesn't match the Earthquake into 4 ohms. I thought all the best amps doubled their power with a reduction to 4 ohms? Nothing to that wives tale? After a day or two, and talking with my inner self, I realize I will only be happy with a bigger amp. So I guess that makes me look at either the Earthquake or the Sherbourn 200 w/channel. Here is what I know about the
Earthquake: 300 w 8 0hm, 600 w 4 ohm, 750 w 2 ohm. SNR 112, THD .01, or .001 depending on rating. Input Impendance of 27k ohms. 1 taroidal transformer with 168,000 microfarads. Has 7 individual monoblocks, so if one goes bad, you can listen to the others. Low/High pass filter for each channel, weights 122.
Sherbourn 2100A: 200 w 8 ohm, 300 w 4 ohm, not rated 2 ohm. AB class at lower outputs, changes to class G at higher outputs. Probably runs cooler than the Earthquake. 7 taroidal transformers for 150,ooo microfarads. SNR 110, THD 0.3. Input Impedance of 40k ohms. Does have 12v trigger options of always on, source or 12v. 2 power cords to assure better power presentation. 110 lbs.
I wonder if the 100 watts would make alot of difference? The THD is much better for the Earthquake. The Sherbourn in about $800.00 cheaper for me. I do have dedicated 20 amp circuits, so don't know about the dual power cords. Thoughts?
Roly
