I don't think you need an SPL meter, or shouldn't need one as Audyssey will get you really close if the procedure is followed correctly. With my system I run it, then listen to a variety of music, then go back and make minor tweeks. When you change what Audessey has set (and you have saved), an asterisk appears next to the value if it's not the same as Audyssey. This way if you change too much or too many things you can always go back and change them back to Audyssey's starting point, evident if all the asterisks are gone.
