I've finished! (until the next mod!)
Hi,
Well, after much 'fun' wrapping panels in fabric, I've finally got my side wall traps on stands and fixed the ceiling ones to, well... guess.
Having read (from numerous sources) that it's better to have a 'soft' ceiling and a hard floor than a hard ceiling and soft floor, I was surprised just how much better the results really are with the same panels moved from the floor to the celing.
For reference, these graphs are the last 'best' results, with the seating position at 38% from the front wall (where the speakers are placed), bass traps in corners, and HF panels on side walls and floor:
http://spikyfish.com/09 all traps, at 38percent - low range.gif
http://spikyfish.com/10 all traps, at 38percent - full range.gif
http://spikyfish.com/11 all traps, at 38percent - 3D.gif
http://spikyfish.com/12 all traps, at 38percent - impulse response.gif
These graphs show the same setup, with the four HF panels that were on the floor attached to the ceiling:
http://spikyfish.com/13 all traps HF on ceiling, at 38percent - low range.gif
http://spikyfish.com/14 all traps HF on ceiling, at 38percent - full range.gif
http://spikyfish.com/15 all traps HF on ceiling, at 38percent - 3D.gif
http://spikyfish.com/16 all traps HF on ceiling, at 38percent - impulse response.gif
The low range response is a little better, though I'm not sure that the ceiling panels would have had that much affect.
The full range response is arguably a little more even, though comb filtering is more evident. The real difference comes in the impulse response measurement - the ceiling was obviously creating fairly significant reflections, which have now been tamed (though, unsurprisingly, the floor reflection is back).
I then put a duvet (no rugs to hand) on the floor where the ceiling panels had been. The resulting measurements are the reason I started down the road of acoustic room treatment!
http://spikyfish.com/17 all traps HF on ceiling, duvet on floor, at 38percent - low range.gif
http://spikyfish.com/18 all traps HF on ceiling, duvet on floor, at 38percent - full range.gif
http://spikyfish.com/19 all traps HF on ceiling, duvet on floor, at 38percent - 3D.gif
http://spikyfish.com/20 all traps HF on ceiling, duvet on floor, at 38percent - impulse response.gif
Apart from a nasty null just under 4kHz, the full range response shows reasonably reduced comb filtering (within 10dB for most of the audible range), and a reasonably flat response. Compare this to the original measurement:
http://spikyfish.com/02 no absorbers - full range.gif
The impulse response is much improved, though obviously only so much reduction in reflection can be expected from a duvet, so a small spike remains.
After every modification I'd run through a few CD tracks to see if I could detect any audible changes. Not very scientific, but after this last round of changes I ended up sitting through a couple of entire CDs, as I was enjoying what I was hearing! Can't give any better recommendation than that.
Huge thanks go out to Ethan, bpape, mrnomas, Chris (WmAx) and all the others that have assisted and inspired me in this quest. Hopefully I'll get some time to put the construction details together in a webpage so that others can have a go at making the panels (or just save yourself the time and buy better ones at
www.realtraps.com
Gordon.
