Having read many many articles on Bass management, I still have some unanswered questions regarding the Bass Management for my HT setup and really would love some advice from those that read and input to this forum.
I appreciate many settings at the end of the day come down to "what sounds right for you." However I like to set anything as technically correct as possible. Hence my debarkle. As most of the written theory written on Bass Management is generic, I am wondering if there is anything specific to Yamaha, In particular the RX-V1500's setup that I should apply to my scenario.
Reading Gene DellaSala's article - The Bass Management Dilemma, I came across the following and am now wondering if it overrides all other theory for Bass Management when it comes to the RX-V1500?
Quote:
"What About THX Systems?
THX is almost a different beast altogether. A THX Select or Ultra2 system is specifically designed to have the bass management set at 80Hz. While you are free to alter the crossover frequency of a THX system, you will not be utilizing the system as it was intended to be heard. In addition, THX processing and DSP assumes (and sometimes initiates) an 80Hz crossover setting for the LFE. While a THX system may not be desired by everyone, we actually recommend those systems (assuming THX speakers in conjunction with a THX receiver/processor) be configured as recommended."
My System Comprises
Yamaha RX-V1500
Front L&R: AAD (American Acoustic Development) C600i
20-180watts, 91dB, 6 ohms, Response - 32Hz-20KHz (BiWired via Speakers A&B outputs)
http://www.aadsound.com/Products%20Page/C%20Series%20Product/C600i.html
Centre: AAD C401i
20-180watts, 91dB, 6 ohms, Response - 40Hz - 20KHz
http://www.aadsound.com/Products%20Page/C%20Series%20Product/c401%20product%20page.html
Rear: Wharfedale Valdus 100 (v.1)
100watt (180w peak) 8 ohms, Response UNKNOWN
Drive units: 120mm polypropylene bass, 28mm dome tweeter
Sub: Velodyne CHT-10R
175watt (375 peak), 28Hz-120Hz (+/-3dB) LP Crossover set to Direct.
http://www.velodyne.com/velodyne/products/specs/cht_r.html
Yamaha YPAO sets the above configuration when the Equalizer is set to FRONT (Front speakers being of higher quality than all others) as Fronts & Centre large, Rear small, and Crossover at 40Hz.
Equalizer set to FLAT (all speakers of similar quality) Speaker size as above and Crossover increases to 100Hz.
My preferred Mid Bass and treble listening is with the Equalizer having been set to FRONT. The FLAT setting seems to really reduce the treble and upper frequencies of the Front L&R speakers.
Seeing as 90% of my usage is Home Theatre, do I set all speakers to SMALL and run the crossover at 80Hz per THX as this Receiver has some sort of THX stamp?
OR-
Do I leave settings per YPAO with Equalizer set to FRONT making the Fronts and centre LARGE and rears as small and override the crossover setting to say 80Hz in compensation for the small rears?
OR-
Perhaps equalizer as above and all speakers set to small with the crossover at about 60Hz making the assumption that not a whole lot of lower frequency information gets sent (therefore lost) to the rear and 60Hz is about an octave above(?) the lowest range of the fronts & centre?
Your guidance and feedback is appreciated. My juvenile ears are improving however I believe that if the system is set technically correct then I'm more than 1/2 way better off than guessing the correct setup.
Thanks in advance.
Aaron
