Hello audio guys.
I am an IT guy (computer/networks). I came here to learn a bit about audio setups. Thanks for any help and tips.
I bought a set of Yamaha speakers on amazon and an in-wall audio interface for a lobby that needs some ambient
music at low levels.
I got this:
I was not expecting much juice from it, as this setup is intended for a lobby with low level ambient music,
but the problem here is the sound that comes out of this little inwall chinese herdio amp unit is just plain horrible, my laptop
outputs better sound quality i believe.
I need an AMP.
I bought the in wall unit trying to keep things neat and less wires but i understand i need a bigger amp here.
i see there is those Pyle units all over in Amazon, claiming 200 watts in the 50-90 dollars range but they are rated for 4oms setups,
and my little knowledge about how audio speakers and amp works tells me that should make it half of the claimed power.
Would you guys suggest a few options or the specs i should be looking at to match these Yamaha speakers i got with something that makes sense?
I just need a 2CH setup with the standard RCA inputs, 3.5, BT, and basic equalization that sounds clear and clean at low volumes, while having the
ability to get cranked a bit in case they ever need a meeting party in the lobby.
I am trying to avoid using a bigger size head unit like those home theaters.
Thank you
