I just read your blog.
http://clearcenterchannel.com/
I wouldn't think a person would register the domain just for the purposes of trolling us. Seems he invented the concealed camera.
He took the thread and used it as an example on his forum then sold his product as the solution.
He goes as far as to say an improvement in the center channel wouldn't make a difference or that running it hot wouldn't help. He fails immediately on both points.
An upgraded center most certainly improves sound in the center channel. For example when I used to buy commercial speakers. I upgraded my Infinity Beta 250 to a 360 and the dialogue was way better. In fact the speaker was better than my L-R channels at dialogue.
On his 2nd point. I would disagree again. I've found running the channel 4 db hotter makes a hearing dialogue much easier furthermore dynamic range compression also helps.
Finally most folks have poorly setup theaters with the L-R channels right next to the TV and surrounds way too close to their ears. Dolby and others mix their stuff so folks with proper setups get maximum benefits. I can't tell you how many folks have jacked up home theaters. Mine is currently messed up too. I can't wait to have my own home theater room.
