Just take care to tighten them as much as you can so if you wiggle the wire, then cable doesn't fall out, you should be fine. The better bananas will stay put better.
If you are really concerned, get some JA Mitchell versions $7.50 each CAD, they pass the wiggle test, OR go bare wire.
Bare wire is just as good, just not convenient.
