So after much research and deliberation, i decided to spend the money and have a professional audion technition come to my home to optimize my system and make it the best it could be. Now, due partially to my own laziness and preference to use the same company, I opted to use Circuit Citys "Firedog" service. I told them i didnt need an install or anything because everything worked fine. I just wanted it to be set up perfectly. Long story short, the guy that showed up simply looked in a few manuals, adjusted the balance on a couple of speakers, and that was it. $170 to not even do as much to the system as i had already done. I asked if he would be using any electronic devices to measure anything and he said no. What about any special programs to run to test things? Nope. Have to purchase that stuff on my own.
That was pretty much it. I called CC and they told me T.S. I will no longer be making any more purchases from them. Nor do I recomend Firedog. Unless you cannot read, then you should call them i suppose.
