First place to start would be a B&W dealer since they have the direct lines to repair facilities and B&W. You can possibly get the info from them and take care of it yourself, or usually manufacturers will just send you a replacement amp since it is almost 100% likely an amp failure. If it is within warranty or is a known issue (longshot, but possible as some mfg have longer warranties) that amp could be free.
