B&W 803D4 or Monitor Platinum 300G3
  • Thread starter Thread starter Bigbuck
Bigbuck
Right now I have JBL's HDI-3600's. They are only decent sounding, so looking to upgrade. I had a set of Monitor Audios silver series before my current JBls that sounded great, but couldn't take much power. ( I like it loud!).
Im driving them with a Michi S5 amp. which outputs 500W @ 8ohm / 800W at 4 ohm.
I mostly listen to rock / pop. and movies too.
SO, help me decide!
SO, help me decide!
If you like it loud then the B & W for sure. The midrange driver on those Monitor Audio speakers are too small and not powerful enough for loud.
Neither of those choices are particularly good choices.
For its price the B & W measures very badly.
For a speaker costing that much, that is a total and complete disgrace!
The Monitor Audio is nothing to be proud of either.
That speaker is going to be a bit of a boomer. It has a peak right at the "boom" frequency, then the bass falls like a rock. I don't know how, but they clearly have managed to mistune it. In this day and age that is inexcusable. The tweeter is suffering break up as early as 10kHz.
Unfortunately there are far more bad speakers than good ones still. Price is no guide as to whether a speaker will be any good. There are plenty of dreadful speakers that cost a fortune. It is no good asking me what I use, as I design and build my own, and with good reason. I would never be proud to claim I designed either of those.
John Atkinson's measurements for Stereophile can make it look like there is more bass than in reality. His measurement technique doesn't really capture bass at the same level as the rest of the range. Don't judge the bass response of a speaker by Stereophile's measurements.
Ive read very very good reviews on both speakers, and I know the Monitor Golds sound really good....at least in a small room.
I haven't heard the B&W's as no one carries them near me.
For $25K/pair, better actually listen to them in person first and not just someone’s opinion.
I think the 803D4 look better aesthetically.
Both will probably sound about the same. Both have a small 4-5” midrange driver and just two 7-8” bass drivers. Nothing to brag about here.
If you want to listen loudly, maybe get more dynamic speakers with much bigger drivers. Maybe 8” midrange drivers and dual 12” woofers.
Does anybody know who carries these speakers in the Milwaukee / Chicago area?....Im not having much luck finding a place where I can listen to them.
No, but try calling the companies direct and ask what is the closest B&M to you
I was not a fan of the Monitor Audio Gold and prefered the HDI-3600 personally. If you like it loud and want big dynamics, I would also look at Arendal, either 1723 or 1528 if you have the budget. In home trial so you can return them if not happy. Audioholics has reviewed them (just the bookshelf for the 1528 so far) and they are well recommended.
Eh, if you want speakers that kick ass, I don't think you have to spend that much. At least get an audition and crank up a set of Martin Logan Motion XTF-100/200 towers. With their 6.5 inch mid-range drivers and AMT tweeters, you can't believe the dynamics on these things, i.e. drum shots, rim shots, brass attacks, etc. I think they can be heard at Best Buy Magnolia locations. Make sure they drive them with a separate power amp and crank them up. I heard them on a 200 wpc McIntosh power amp. These are the XTF-100's, which are rated for up to 450 watts amplifier power. The XTF-200's are rated for up to 600 watts. The XTF-100's were reviewed here on Audioholics:
I have a feeling that when people spend $25K on speakers, it’s more than just about SQ.
Back when I bought the B&W 802D2 brand new for $12K, it was also for aesthetics and pride of ownership, not just SQ.
When I bought the Revel Salon2 brand new for $14K, it was also for aesthetics and pride of ownership in addition to SQ.
Gotta be really really happy when you spend big money.
Those Martin Logans look interesting. I will research more.
Also now considering Sonus faber Sonetto VIII G2....once available.
My main speakers now are Sonus Faber Lumina V, which is the largest tower in the Lumina series. They are nice sounding speakers, but not particularly dynamic in the mid range. I realize the Sonnetto line is one step up from Lumina, but I don't think SF designs for the kick ass abilities that you seem to be looking for. But, of course, get a listen to them and any other speakers being considered.
image_large
Nothing special. F3 is 50Hz and 25 db down by 20 Hz. Mid and HF response ragged.
