Found it.
The AWG is based on two wire diameters (AWG 0000 = 0.46 inches diameter and AWG 36 is 0.005 inches diameter), and that there are 38 different sizes between the these two gages (wire is gage, a gauge is something that show temp, pressure, volts, amps, etc..). The ratio between one gage and the next larger gage is defined as the 39<sup>th</sup>th root of 0.46/0.005 or 92, which equals 1.1229322.
5 basic parameters are developed from these relationships
1) An increase of three gag numbers doubles the area and weight and halves the resistance.
2) An increase of six gage numbers doubles the diameter.
3) An increase of 10 gage numbers multiplies the area and weight by 10.
4) A 10 AWG wire has a diameter of 0.1 inches, an area of 10,000 circular mils, and a resistance of of 1 ohm/1000 ft.
5) The weight of 2 AWG copper wire is 200 lb/1000 ft
There you have it. Probably a lot more than you needed to know.
