AVR and Equalization (Harman Kardon 132 for example)
jacococo
Hi All,
Here is a simple (but important question).
If I buy a AVR, Harman Kardon 132 for example,
1. Will I be able to equalize the sound in a refined way?
I am not speaking about on which speaker send which frequences BUT : I want more basses, less trebles, simple equalization...
And will it be possible to adjust levels per frequencies?
2. Same question if I use STEREO DIRECT (like in HK 132):
I understand that in that case, what is in goes out without any DSP....
but does that mean that I can't even adjust Bass, Mid and Treble levels?
Thanks
Z
zumbo
Went to HK website.
HK 132 is not current.
HK 132 is not archived.
Can it be "like" another HK?:rolleyes:
allargon
It is archived.
http://www.harmankardon.com/faq/showfaq.aspx?lstProduct=AVR 132/230
http://www.harmankardon.com/product_support/SupportDetails.aspx?Region=USA&Country=US&Language=ENG&cat=&prod=AVR 132/230&sjump=&ky=74F51EA8C5EC3CAD9592FB75D6CBB508&
Here's the owner's manual:
http://manuals.harman.com/HK/HOM/Owner's Manual/Owners Manual - AVR 132 (English).pdf
Here are the specs:
http://www.harmankardon.com/specifications.aspx?cat=REC&ser=&prod=AVR 132/230&sType=C
To the OP,
are you talking about those old school slide equalizers from the two channel world of the 70's and 80's? I thought those went out with Dolby ProLogic. I know about the Hall and Theater options. Is that to what you're referring?
Stereo direct reads just like it sounds--no processing. I don't see pre-outs on this receiver, so it's not like you could feed the channels into an external EQ and amp. However, I'm guessing you could feed your source into an external EQ then send the results of the EQ into one of your analog inputs.
A Stereo-Direct mode bypasses the digital processor to preserve all of the subtleties of older analog, two-channel materials, while bass management, available in the surround and Stereo-Digital modes,improves your ability to tailor the sound to suit your room acoustics or taste.
Z
zumbo
AVR 132 would've helped.:rolleyes:
I was looking for HK 132.:eek:
