I have a problem with my new receiver and I’m wondering if anyone has had a similar problem or knows a solution. It’s an avr-4806s that I set up all inputs and was ready to auto calibrate. I go into setup and select auto setup/room eq. it thinks for a second or two while it displays the wait command. I hear what I think is power relays opening and the playing source cuts out. The system will detect if a mic is plugged in or not but once I select extra setup or start it kicks my up to the parent menu and I hear the relays trip and the previous source starts playing.
I called Denon’s tech support and they thought it might be a bad mike so I got another from my dealer (Saturday Audio in Chicago who are great) and the same thing happened. So I talked to the Denon rep at Saturday and we did about 15 minutes of trouble shooting and he says the unit sounds bad and they will replace it.
Yesterday the replacement comes in and I get the exact same behavior. WTF. I believe the probability of two units having the exact same problem is remote so I am beginning to wonder if I am the problem. Anyone have a similar issue of can think of something to try. I have done countless resets and everything else on the unit is straight forward. I had no problems with assigning the digital inputs, renaming inputs or any other aspect of driving the receiver.
