dobamar
dear friends,
please kindly suggest how to set avr- 3805 with optional denon microphone?my system are denon 3910(d-link, 3rd edition),ar ps2062 for front & back& ps 2052 for centre. sub is velodyne ct-100.i have tried but the result was different with actual size of the speaker.do i need to change the size of the speaker after it ? or what is the best cross over freq for set up.( as i am a medcine man , i don't understand the a/v terms very well).
jcPanny
jcPanny
Speaker size and crossover
In most cases, it is appropriate to set all speakers to SMALL on the receiver regaurdless of the auto-setup selection. To determine the crossover setting, check the frequency response spec of all your speakers. For example, if you surrounds play down to 60 Hz, then 60 Hz, or 80 Hz would be a good crossover setting.
